Creamy gear oil. Now what?
DevonS
After my first fun-filled summer owning a boat, it's time to put her in the garage for the winter. I threw in some stabilizer, ran the engine for a while, then fogged it. So far so good. I pulled the lower plug to check the gear oil and looky looky... nice and creamy. Obviously had lots of water in there.
So, now what? I changed the gear oil, but is this just something I have to/can live with or is this a must-fix scenario?
dehydrated
Re: Creamy gear oil. Now what?
replace seals and gaskets oils cheap keep an eye on it
samo_ott
Obviously you put new oil in it. Do you leave the engine in the water all summer? You either have to change the seals or I would consider changing the LU oil halfway through each season.
DevonS
It's trailered all year except when it's in the water for the day. The exception would be a week or so when I go up North and leave it in a slip. How big a job is changing the seals? I'm guessing I'll have to drop the lower unit and dismantle it.
kbait
Did you use new drain plug gaskets last time? They're supposed to be a one-use item.. especially if you go hercules on 'em to tighten. If you did use new, there's obviously water in there not from drain plug gaskets, so a re-seal would be good.
If you just used the old ones, I'd fill w/high-vis gear oil and use new washers and check it after next use.
