geekomatic
- Feb 12, 2005
- 136
I rebuilt my 2HP Johnson Seahorse.New impeller,new points,coil,plug wire and carb kit. I had issues with the low speed needle valve which I posted earlier.This was fixed thanx to a new needle valve and help from you fine Gents.I popped it in a bucket and cranked it up.It runs OK in "start" and "fast".It dies if I try to put the thing in "slow".I cannot get the needle valves set just right for whatever reason.Screw it.I threw it on the back of my canoe and tossed it in the river just about the time the corp of engineers decided to generate power.It got me upstream for just under a minute before dying.Not a good thing in a strong current.While drifting downstream I noticed that the carb is still puking gas out of the high speed needle valve,just like before.I swear I've got the float set right and the packing was replaced in the valve,so I have no clue why this is happening.The high speed valve is quite loose,however.It actually moves with the motor vibrations??<br />At any rate, I was concentrating on this little problem so much that I floated right past the boat ramp for just under a mile.No chance in Hell fighting that current with an oar.Had to ditch the boat,call the wife,get the truck,go back and get the boat.The sun went down while all of this occured.Just got back and I'm a bit puzzled to say the least. Sorry to ramble.Any idea what's going on? <br />Does any other HP carb fit this thing? I think the carb is really jacked up due to my efforts removing the broken low speed needle valve.<br />Thanks in advance,as always.
