Crankshaft seperation
greenhead1984
Hey Folks,
Does anybody have any recommendations on separating the pieces of a 1999 suzuki 25hp crankshaft to remove the piston rods and crank bearings?
Thanks
J
pine island fred
Re: Crankshaft seperation
Have to assume this is one of those pressed together crankshafts. Someone should come along and put you in touch with a person that has the equip. Might want to consider junking the motor. Not a cheap job. Did it on a YAMAHA 50 awhile back. Was not worth it. FRED
deejaycee_2000
the yamaha 50 should be cheap to do ......
anyway, any engineering crank shop can sot it out for you and it is not too expensive .....
rodbolt
I have sent several built up cranks to Ackermann Marine in Wilmington NC with very good results.
