lakerunner999
- Aug 16, 2007
- 1
Have a Waverunner VXR that was stored for 2 years and now is not cranking. Battery is original but is fully charged and reads 12+ volts on voltmeter. When I press the start button I hear the starter engage but just a very slow rrrrrrrrrrrrrrr from the engine. It has turned a few cycles, slowly, but didn't fire up. After several attempts to start, battery runs down and then just hear clicking.
When I stored this I put Stabil in the gas and ran it for a few seconds (dry), did nothing else to winterize it. It has been through 2 upstate NY winters like that (outside but covered). I'm sure there is nothing wrapped on the impeller preventing it from turning.
Could the cylinders be gummed up/sticky? Does that happen? Is there anything else to easily check before pulling the plugs? Once I do that, how do I crank the engine by hand? Will a little gas/oil mix put into the spark plug hole help lubricate the cylinders to get things moving again?
