jgriner
- Jul 22, 2010
- 146
ive always seen that the starboard side has been covered in gas, finally found the problem yesterday.
ive seen that their are some hairline cracks where the crankcase is connected to the intake manifold.
the cracks are on top of the bolt holes on the top/middle cylinder, i can not see the bottom cylinder enough to tell what shape it is in
what would cause this, when i got the boat about a month ago it had 147-150 psi on all 3 cylinders, can i get this psi with these cracks or has these cracks happened since i got the motor.
can stuff like this be repaired, can it be welded, or maybe jb weld.
if i have to replace the crankcase, how much should i expect to pay for the parts?
