Re: Crankbait Rod
there are pros and cons of fluoro. on cranking rod. # 1 pros being that it sink so you can get the bait run deeper, it abrasion resistance. You don't have to worry much about line stretch since the fiberglass will absorb the shock. The #1 cons being that it expensive to replace often like you should, you don't needs fluoro on a fast moving bait, since there are no stretch, you can't snap the line to free your bait when it hang up. To me fluoro on cranking rod is a waste of money. There may be other thought out there.
