dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I started the engine Mercruiser 4.3 v6 on the boat I recently purchased (1985 Larsen). The engine (at least some parts of it, not the block itself) and outdrive I was going to put into my newer 2005 Larsen boat, which has no drivetrain. So this engine appears to run (surprisingly since it was not ran since id guess 2012). But I also found out that one of the freeze plugs has popped out and there is a mini crack in the exhaust manifold. Most likely it happened when the previous owner forgot to winterize the engine and left some water in the engine. Since I live in Phoenix this does not happen at all here, but the boat was in Flagstaff, where in winter the temperature goes below the freezing point. So the question is, is there any way to seal or weld this little crack on the exhaust manifold (I have an access to various welding machines - MIG and TIG welders, plasma cutter) or should I just buy a new exhaust manifold, they go for about $180 on ebay for GLM and a bit more expensive for Sierra or Mercruiser replacements? Thank you.
