We purchased a 97' deck boat with a Yamaha inboard/outdrive engine on it. We put the boat in the shop to have the transom replaced. They had to pull the engine to do this. After replacing the transom the tech called me and said it should be ready in a couple of days. They were going to take my boat out and make sure they checked all the leaks. I also asked them to check the engine and make sure everything worked find before we got it back. His reply was that the engine was in perfect condition, no problems. The next day they called back and said no leaks but that the engine did overheat while they had it out and they needed to put a new waterpump on it. I told them to go ahead and he said eveything else looked great. Called yesterday and said he had bad news....the engine had a crack in it and we needed to replace it. Big $$.
He said he checked the oil when we first brought it in and it was clean. Checked oil yesterday and it had water in it. We took boat out in March and ran engine for 4-5 minutes when we noticed water coming in around the transom. That is when we took it in for repairs and checked oil and said it was clean. If the engine had crack in it prior to taking it in for repair would it not have gotten water in the oil at the time we first took it out? And also would they not have seen the crack when they pulled the eingine to replace transom? Could the engine overheating because of bad water pump cause the engine to crack? We just don't want to get taken and we are afraid that maybe they are trying to take us. Please help.
