lncoop
- Apr 18, 2010
- 5,147
I just picked the barge up from the upholstery shop today and took her down to the river for a first of the season shakedown cruise. I backed her in and fired up the motor only to discover I had no reverse. My first thought was a spun hub, so I popped it in forward to see what would happen. Forward was strong, so I pulled up out of the way to investigate. I pulled the prop and found this.
From what I understand that's the outside of the bearing carrier assembly. It's broken on top and bottom and the light gray is the distance between where it is and where it should be. I can push the shaft in at least half an inch and probably more.
What could have caused this? We went to check on the boat last week and it had been moved. Could they have backed the prop into another trailer tongue or something hard enough to do that? If so, would that have caused the loss of reverse? What are the the other possible causes? I think I would know if I had hit something in the water hard enough to do that kind of damage, and my top speed is around 25, so that seems unlikely anyway. And, it worked fine last time I ran it. If the upholsterer caused this I want him to take care of it, but I don't want to blame him unfairly. Thoughts?
From what I understand that's the outside of the bearing carrier assembly. It's broken on top and bottom and the light gray is the distance between where it is and where it should be. I can push the shaft in at least half an inch and probably more. What could have caused this? We went to check on the boat last week and it had been moved. Could they have backed the prop into another trailer tongue or something hard enough to do that? If so, would that have caused the loss of reverse? What are the the other possible causes? I think I would know if I had hit something in the water hard enough to do that kind of damage, and my top speed is around 25, so that seems unlikely anyway. And, it worked fine last time I ran it. If the upholsterer caused this I want him to take care of it, but I don't want to blame him unfairly. Thoughts?
