SmurfOnAScarab
- Aug 10, 2008
- 20
I have a Force 125 attached to a 89 Bayliner Capri 1902 cuddy. (19ft)
Does anyone have a similar setup? What top speed are you reaching?
Also, does anyone have timing specs? I had the timing light on the engine last night after installing a new piston, and with the light at 0 deg, it looked as if the mark on the flywheel was about 4 degree's advanced at idle.
I looked through the Seloc manual, but couldnt find timing specs unless I just missed them.
Any help would be appreciated.
thanks
thanks
