Ok got to run in the water after new tach install. Note: carbs have been rebuilt, new filter and fuel lines new fuel.
Boat was hard to start, starter would turn engine over then disingage. I thought it was due to back pressure and when I tilted it out of water she turned over and fired off quickly. Batttery is fully charged(only two weeks old) I'll check connections again. Boat ran good, with two on board ran up to 5300 rpms, 32.8 mph. All good. Went to pick up a buddy in a creek and idleing down his creek boat was dropping rpm slowly. By the time we got to his house it stalled out. Ended up having to adjust idle up to get it to run. Checked timing with light at idle and it would only run if it was around 8 degrees with the idle screw turned in alot. Primer bulb would not stay hard all the time. Have to check all lines for leaks. A note: Coils all look bad, cracks and gouges in them. Could boat get to running warm and coils heat up and start cutting out? I can get my hands on 4 used good coild for $40. I think I'll change all four and try agoain. Any other thoughts. Ran boat back to ramp and it seemed ok but would hestitate at first and then run good but only to right at 5000 rpm. Go home and it was running at 2000 rpm on muffs on trailer. Readjusted timing back to where it was and idle also. My thoughts are power pack or coils.
