reece204
- Sep 12, 2016
- 3
Quick question guys. I have a Mercruiser 3.0 I/O on my 1998 Bayliner and never had any issues. Took it out last week and it ran perfect. Took it out again this week and went to start it and it would turn over but no spark. Checked all plugs and wires and cleaned all connections and checked the spark plugs for wear or indications of flooding and all was good. So I went to the store and bought a spark tester, hooked it up and turn the key and the engine turned over perfectly but it was showing no spark at all. I did notice the battery gauge with the key on was showing about 11-12 volts, but since it was turning over fine I didnt think much of it. So after doing some research I was thinking it was likely the ignition coil. Before ordering a new coil I just decide for the heck of it to try it again, I turn the key and surprisingly, it fired right up and ran normally. I turned it off and on about 10 times and started and ran perfect every time (and the battery gauge showed close to normal this time before starting and 13-14 volts as normal running). So I let it sit for the rest of the day then try it again and we are back to square one, turning over fine but no spark at all from the coil. I called a repair shop and they are still trying to sell me a $200 coil saying that they think that is the problem. My question is, could it actualy be the battery and is it possible that it has enough cranking amps to turn over but not enough volts to produce spark? I didnt think that was possible which is why I am asking. In my opinion, if it was the coil having an intermittent issue you would think it would fail while the boat was running and cause it to lose spark and stall and not only be a problem when starting. To sum it up, today I just turned the key again and it is starting and running perfect once again. I tested the battery before starting with a tester and it showed 12.7 volts. Any ideas?
