nathanhooper
- Apr 21, 2010
- 176
I am having some corrosion issues with my 79' I-6. I also am having some water intrusion into cylinder(s). I have another post going with that, because I am hoping it is the lower crank seal and not related to the extreme corrosion I found when pulling the powerhead to replace the seals.
In the first photo you can see a small crack, that pretty much just flaked off when I touched it, the aluminum was very, very thin. I then decided to take off the exhaust cover to look in it and found even more corrosion. It also ate through the inner jacket cover, but in the water passage area, not the exhaust side. Hopefully you can tell what I am talking about from the pics.
This has really got me stumped because the motor was very clean looking. It is not a saltwater motor that I know of, but looking at the corrosion issue I cannot see how fresh water would do this to one. Anybody have some comments or pictures of extreme corrosion caused by fresh water?
I am going to pull off the head cover to take a look in there. Is there a chance that I could have corrosion eating through the cylinders? I did a compression check on it when I first got it. No signs of any weakness, but I did have it running and am wondering if it running managed to stress it enough to cause a crack to form.
This never crossed my mind or else I would have already done another compression check, I will be doing that tonight. I just thought I would get some insight from the helpful folks on here today while I mull over my options on this motor. Like, at what point does corrosion become too bad and is a risk of breaking through and causing serious problems while out on the water?
Hopefully you can see the extent of the wear it has caused. There are quite a few places where it feels/sounds like I could take the tip of a screwdriver and with minor force punch through the metal.
