Corroded Battery Clamps
dr_detroit99
Why do my trolling motor battery clamps get corroded over time? <br />How can I prevent this?<br />Thanks
SlowlySinking
Master Chief Petty Officer
Re: Corroded Battery Clamps
There are probably 16 dozen ways to do this, but <br />here's what I do, remove the clamp, wire brush it and the post until shiny, replace and tighten, coat with a layer of chassis grease, years from now it will be corrosion free. :)
JB
Your clamps are copper. The posts are lead.<br /><br />The result is electrolysis. <br /><br />Disconnect them when not in use.<br /><br />Good luck. :)
ebbtide176
and if you don't feel so inclined, read the first part of jb's post again... it bites eh? :D even if they're brass or lead, there will be some diff in the bolts or something...<br /><br />i used to have a startup job of cleaning battery posts - i still am sensitive to that smell, you know, the bluish white powder on the terminals. i liked using baking soda in warm water (so it would mix), then lay the terminal ends down in it (a disposable party cup) until they quit bubbling, pour out and repeat @ 2x. then clean like SS listed. then rub real good with some kind of O2 inhibitor (grease is good) and clamp up again. yes, rub it all inside every surface, it'll squeeze out later. spray/rub down what got exposed during reclamp. sit back & enjoy a good connection :D lol<br /><br />for the ole wives tail of grease being a nonconductor, and preventing the connection from being correct.... true- but only for the spots that aren't metal-to-metal . so go with grease or the nice red batt spray. heck, vaseline, lard, even the spray from a fire extinguisher would work. same principle ;)
chuckybaby
There is a product called "NO-OX" that we use on battery terminals in the Telco power rooms (and let me tell you, we phone companies have a lot of batteries) It's a conductive grease like substance that you smear on all exposed metal. I use it on all of my batteries..all of the time. You may have to look hard for it ...try the big electrical supply houses...but it's worth the effort.
Spidybot
...and another:<br /><br />After the thorough cleaning you refit clamps, tighten and cover it with Automotive Anticorrosion Body spray (preferably the thin type, that stays sticky).
Ralph 123
The following is a list of paste and grease-like products for the <br />prevention of oxidation of aluminum in electrical connections and <br />antenna installations: <br />---------------------------------------------------------------- <br />Manufacturer: <br /> Butternut Electronics Company <br /> 831 North Central Avenue<br /> Wood Dale, IL 60191 <br /> Tel: (708) 238-1854<br /> Fax: (708) 238-1186<br />Product Name: Butter-It's-Not <br />Source: Direct if not stocked by local authorized dealer. <br />Price: $3.50/ Envelope <br />NOTES: Contains copper dust in a molybdemum suspension. <br />-----------------------------------------------------------------<br />Manufacturer: <br /> GB Electrical<br /> 6101 N. Baker Road<br /> Milwaukee, WI 53209<br /> Tel: 1-800-558-4311<br />Product Name: OX-GARD <br />Source: Available from many electrical supply houses and retail <br />outlets such as Sears, Home Depot, Ace and True Value Hardware <br />stores. No Factory direct sales. <br />GB catalog number OX-100B. <br />Price: Approximately 3.00/ 1-oz tube<br />-----------------------------------------------------------------<br />Manufacturer: <br /> Ideal Industries, Inc.<br /> Becker Place<br /> Sycamore, IL 60178 <br /> Tel: 1-800-435-0705<br /> and: 1-815-895-5181<br /> Fax: 1-800-533-4483<br />Product Name: NOALOX <br />Source: Distributors (Call 800 number for nearest one)<br />Price: Ideal list price $2.58/ half oz tube (#30-024) and <br /> $8.64/8oz bottle (#30-030). <br />NOTES: Also available from many electrical wholesale supply houses.<br /> No factory direct sales. Contains zinc particles suspended <br /> in a carrier. <br />-----------------------------------------------------------------<br />Manufacturer: <br /> KLM Antennas Inc. <br /> PO Box 694<br /> Monroe, WA 98272 <br /> Tel: 1-360-794-2923<br /> Fax: 1-360-794-0294 <br />Product Name: Conductive Paste <br />Source: Factory direct and larger dealers. <br />Price: $3.50 plus shipping & handling/ 1 ounce containers <br /><br />NOTES: Anti-seize thread compound Hi-Temperature MIL-A-907E. <br />Contains copper and graphite flakes suspended in a petroleum base. <br />Manufactured for Mirage/KLM by Chemical Commodities Agency, Inc. <br />of Highland, CA per MIL-A-907E. <br />----------------------------------------------------------------<br />Manufacturer: <br /> Sanchem, Inc.<br /> 1600 S. Canal Street<br /> Chicago, IL 60616 <br /> Tel: 1-800-621-1603 <br /> Out of State: 1-312-733-6111 <br /> Fax: 1-312-733-7432 <br />Product Name: NO-OX-ID<br />Source: Direct from Manufacturer<br />Price: $11/16oz can or $8.80/8oz tube (plus shipping)<br /> Minimum order - $35<br />NOTES: NO-OX-ID comes in several consistencies. NO-OX-ID "A" and <br />NO-OX-ID "A-Special" are suitable for most antenna installations. <br />NO-OX-ID "A-Special" is similar to NO-OX-ID "A" but has a small <br />amount of solvent added for ease of application. <br />-----------------------------------------------------------------<br />Manufacturer: <br /> Thomas & Betts Company<br /> 1555 Lynnfield Road<br /> Memphis, TN 38119 <br /> Tel: 1-800-888-0211 <br /> Fax: 1-800-888-0790 <br />Product Name: Aluma-Shield<br />Source: No direct factory sales. Available from many electrical <br />supply distributors.<br />Price: Approximately $11.44/ 8oz can. <br />NOTES: Customer may call 800 number for location of nearest <br />distributor. Contains zinc particles suspended in a petroleum base.<br />-----------------------------------------------------------------<br />Manufacturer: <br /> Burndy Electrical<br /> 101 E. Industrial Park Dr.<br /> Manchester, NH, 03108<br /> Tel: 1-800-346-4175 <br /> Fax: 1-800-346-9826<br />Product Name: Penetrox (PEN-A)<br />Source: Electrical wholesalers<br />Price: Approx. $6/ 3oz tube<br />NOTES: Zinc particles suspended in a natural based compound. <br />-----------------------------------------------------------------<br />Manufacturer: <br /> Ilsco Corporation<br /> 4730 Madison Road<br /> Cincinnati, Ohio 45227 <br /> Tel: 1-513-533-6200 <br /> Fax: 1-513-533-6274 <br />Product Name: DE-OX<br />Source: No factory direct sales. Available from electrical <br />supply wholesalers and distributors. Customer may call for <br />nearest distributor.<br />Price: Approximately $2.90/ 1oz, $4.90/ 4oz and <br />$7.30/ 8oz squeeze bottle.<br />NOTES: Used in the electrical trade for Al/Cu and Al/Al connections.<br />Green colored grease with no noticeable particles in suspension. <br />-----------------------------------------------------------------<br />Manufacturer: <br /> Antennas West <br /> PO Box 50062 <br /> Provo, Utah 84605 <br /> Tel: 1-801-373-8425 <br /> Fax: 1-801-373-8426 <br />Product Name: Goose Grease<br />Source: Factory direct sales only. <br />Price: $1.00/ 1oz + and $1.00 p&h. <br />NOTES: Transparent silicone grease. Antennas West also recommends <br />this product for ground rod clamp connections.<br />-----------------------------------------------------------------<br />Manufacturer: <br /> Mosley Electronics, Inc. <br /> 10812 Ambassador Blvd.<br /> St. Louis, MO 63132 <br /> Tel: 1-800-966-7539<br /> and: 1-800-325-4016<br /> and: 1-314-994-7872 <br /> Fax: 1-314-994-7873 <br />Product Name: 1) Mosley Penatrox (Conductive Grease)<br /> 2) Weather Guard (Clear spray coating) <br />Source: Factory direct sales only. <br />Price: Mosley Penatrox- $4.45 / packet + postage.<br /><br /> Weather Guard- $12.75/ 8oz spray can + shipping<br />NOTES: Mosley Penatrox is a greaselike product. Weather Guard is a <br /> clear spray especially recommended for marine and coastal <br /> environments. Weather Guard cannot be shipped via the post <br /> office; UPS required. <br />-----------------------------------------------------------------<br />Manufacturer: <br /> Loctite Corporation<br /> 1001 Troutbrook Crossing<br /> Rocky Hill, CT 06067-3910 <br /> Tele: 800-842-0041<br />Product Name: Permatex ANTI-SEIZE LUBRICANT<br />Source: Many Automotive Supply Distributors <br />Price: N/A <br />NOTES: Comes in 1 oz squeeze tube, 8 fluid oz brush top container, <br /> and a 12 oz aerosol can. Can be used on the threads of <br /> U-bolts to prevent "seizing, galling, and corrosion." <br /> It aids in the disassembly of the the antenna's hardware. <br /> Not for use on electrical connections. The part no. on <br /> a 1 oz tube is 133A.
