Correct wiring for hour meter
HT32BSX115
Re: Correct wiring for hour meter
Howdy,
Most people wire them to any source that is powered when the "key" is on.
The only problem with that is if you leave the key on inadvertently, the hour meter will run until the battery goes dead.
You could get a normally open oil pressure switch that would connect power only when the engine is running but that's WAY over kill!!
Depending on where you mount the hour-meter, Just connect it to any power source that is on when the ignition is powered.
Many hour meters will operate as low as 6-7vdc ...... so you could also connect it directly to the coil + terminal if you mount it in the engine compartment.
http://content.honeywell.com/sensing/hss/hobbscorp/cat1_hr5.asp
Regards,
Rick
JustJason
What alternator do you have? If the alternator has an AC leg on it, you can grab your power from there.
seabob4
The easiest way is to power it from the "Run" circuit of your ignition switch, the purple wire. But you MUST turn your key switch to off, or, as HT said, it will continue to rack up hours...
Silvertip
It's wired the same way for an outboard. Key on, meter runs.
Allbutwet
For an inboard it is best to install a pressure switch on the engine block. This way the hour meter is a true reading of actuall engine hrs. You may already have one on the engine. In this case you can tie into it for your hour meter.
JustJason
Depending on the outboard, you can usually grab power coming off the battery charge coil that runs to the rectifier.
