Re: Correct way to change gear oil on OMC Cobra?
The Cobra owners manual says you should fill from the bottom using a pump, untill it comes out the middle hole. Then put the bottom and middle plugs back in. Then fill from the dipstick hole (on top) till its completely up to the correct level. Put the dipstick back in. Raise and lower the drive up and down a couple times. Recheck the dipstick level and top off as necessary.
??? Just curious, which Cobra owners manual did that come from?
I've got an '89 4.3L cobra. My owners manual, the OEM 1989 OMC Service Manual, and a Clymers manual covering Cobras from '86-'93 all state the same procedure. You remove 'dip stick' on top, drain oil from bottom hole, replace bottom plug, fill from middle hole with pump until oil reaches appropriate dipstick level
with dipstick resting on top of hole but not screwed in. Then tighten dipstick, replace middle screw, wait a bit and recheck. After this point all measurements should be made with the
dipstick screwed in . Top off from the top dipstick hole as needed until you've got the appropriate level in the drive.
You should note how much oil your drive takes (64 oz for my 4.3L) and make sure thats pretty close to what you put in when you refill the drive. Then recheck the level several times (after everything settles for a little while, after starting it the first time, etc.)
Several people on here fill from the bottom plug to the middle plug, then from the middle plug to the dipstick, and I have no doubt that works as well, but the OMC Cobra recommendation is as I outlined above.
