kfa4303
Banned
- Sep 17, 2010
- 6,094
Hi all. Does any one know the correct gauge copper core spark plug wires I need and/or spark plugs for my '61 QD-22 10hp Johnson? I think it's 7mm wire and I've been using Champion J8C spark pugs, but I'm not sure if those are the best ones. I've also heard folks use Champion J6C too. I only ask because, after nearly exhausting my bag of tricks to get this old motor running, I think there's still one more thing I need to try before I use it for target practice or send it down to Davy Jones' locker once and for all.
Thus far I've replaced the impeller, thermostat, clutch dog, points condensers, carb kit, and Lower unit seal kit and got her running well in a test tank, but I get nothing but sluggishness and rattling at WOT while under way. This, along with excess unburnt fuel, leads me to believe the that I'm really only running on one cylinder despite the fact that the motor starts with half a pull, both s'plugs make a spark when grounded to motor and she idles well.
While I was getting spark it was pretty weak. I know it needs to jump a 1/4" gap and since I've already replaced the points and condensers, I assume that means the s'plug wires are the weak link. I snipped a bit off the end and the copper is greenish/gray and brittle and the boots twisted right off in my hands with almost no effort. Am I on the right track, or is there something else I could be missing? These things are so simple I'm not sure what else it could be. I'm at my wits end with this thing if this doesn't do it I'm gonna have to cut my losses and throw it off a cliff..... as soon as I find a cliff in Florida.
Thanks for any help.
