Correct Ratio
denblaq
Does anyone know the correct gas/oil ratio for a 1963 Mercury 500 50hp outboard ? Is it 50:1 or 24:1
Thanks, Denis
Capt Ken
Re: Correct Ratio
Back yonder they were doing 24:1. Fouled a lot of spark plugs.
Capt Ken
Re: Correct Ratio
Seen the inside of many an old motor and don't see why running 50:1 wouldn't be a problem with the newer more advanced 2 stroke oils on the market now. Lots of difference from the old oils of yester years.
steelespike
Re: Correct Ratio
My aftermarket service manual covering Merc 4 and 6 cylibder outboards1955-65.
It says Mix 12 ozs Formula 50 Quicksilver( assuming todays TCW3 rated oils meet these specs) outboard oil with each 5 gallons. Thats less than 50:1 2.4 ozs per gallon.
I would stick with 2.6 ozs per gallon.Again assuming the TCW3 oils meet the same standards.
You might go to johns old mercury web site and ask if todays TCW3 rated oils meet the same standards.
I can tell you My 65 Merc 500 has run on 50:1 all its life.
64osby
Re: Correct Ratio
Ran my 67 Merc 500 on 50/1, always made it a little heavy on the oil, just to make sure.
tomhath
Master Chief Petty Officer
Re: Correct Ratio
I had a Merc 350, circa 1960. Called a Merc dealer and they said to use 50:1. It's really the oil rather than the motor that determines the mix.
