Model # 70ESL75B 70HP Johnson motor<br />Looking for opinion and information on the correct prop for above noted. Present prop is marked "Michigan 001005" (or 001003 as it is unclear). It measures 13inches in diameter. The motor has 13 splines on the prop shaft.The motor is on a 15ft TriHull. <br />I really need someone to recommend what prop should be on the motor. Inparticular diameter and pitch. My present prop is damaged.<br />Thanks
