Correct Impeller for 5.0 GL PEFS
Rupp
Guys,
Last year I replaced my impeller with part # 3862567 (21213660). This issue with this part was that the round gasket that came with this part was too small in thickness. The result was I had a leak all last season. Is this the correct part number for my engine?
Thanks for any assistance in advance.
spoilsofwar
Re: Correct Impeller for 5.0 GL PEFS
Is yours a crankshaft mounted pump or bracket mounted pump as discussed in that bulletin?
bajaunderground
wWas it a factory replacement? My OEM VP replacement included 4 different gaskets for the sea water pump. Same impeller!
spoilsofwar
Yep, that's what I was getting at. If yours is one of the bracket pumps ( and I was assuming it was since you said gasket and not oring) it should be coming with four gaskets. You have to use the right one.
