Correct fuel pressure for 1989 Evinrude 150HP V6 outboard
bakerjw
As I've been working through my boat and outboard, I recently rebuilt my 3 carburetors using OEM rebuild kits. i.e. gaskets, new floats and float valves. There really isn't much with these carburetors to screw up. I unscrewed the jets out of the bowl and verified that they were clear of any obstructions. The outboard starts much better now that this has been done.
Last night I took the boat out and it wanted to fight me a bit starting, but it finally started and I let it warm up before going out and getting it up on plane. I ran around 4700 RPM as measured by the tach which is where it was running before I did the carburetor work. Later in the evening when I was going to run it a bit before coming back to the dock, I'd give it throttle and it would start to build RPMs and then it would lag and die. It certainly seems like it is starved for gas which would be indicative of stuck float valves or a poorly performing fuel pump. Unfortunately I was out alone; otherwise, I'd have had someone pump the fuel bulb to keep pressure into the fuel pump while throttling up to see how it behaves.
I will be doing that this weekend sometime. In the meantime, I'm looking at getting an inline fuel pressure gauge. What is the maximum fuel pressure that I would expect to be dealing with on this year of engine? I've found an acceptable inline gauge that goes up to 15 PSI. Would that work well?
I am leaning toward a rebuild of the duel pump as my next step in the process.
phoenixgold2100
Re: Correct fuel pressure for 1989 Evinrude 150HP V6 outboard
I put an inline filter in my 1999 Johnson 150. I know it doesn't tell you fuel pressure but it's glass and I can see when it's full or not.
One thing to check is the fuel filter #433190
Was it cutting out before the carb rebuild? Did you blow the carbs out maybe some dirt in em..
Also it may be sucking some air from a loose or cracked fuel line.
There is a way of testing your fuel pump if you search it on here you''ll find it.
boobie
At 4500 rpm the fuel pump should put out 2.5 psi.
