Howard Allen
- May 29, 2001
- 38
Second post of the day. My 28HP evinrude was very disappointing in its performance pushing my 14 foot Starcraft. With 4 people aboard she would hardly plane. Motor started fine and seemed to run ok and compression is 110 PSI both cylinders. Come to find out, the control isn't the right one. When I put it in forward, the cable does not have quite enough throw to move the neutral lockout lever completely out of the way of the timing plate restrictor so the synchronization with the carb wasn't there. Right now I have adjusted the cable to give me forward and neutral, but there is not enough throw for reverse. The boat now goes like Heck! Anyone know what control should work with this motor. The one I have is a little strange in that the shift lever works backwards so moving it forward gives you reverse. It has two levers with no other knobs or switches and has been painted gray.
