cooling
luisito
i have cooling problem with a mercruiser 120 hp 4 cil eng. overheat twice i change impeller, water is flowing thru but is mixing with the oil i remove the head and find few holes cloged and debris the gasket look fine what you think the problem is.
hondon
Re: cooling
If you are certain that the gasket sealed and head is not warped ,then you will have to consider a cracked block.Are you in an area that has freezing temps for more than a couple hours a night?That can be all it takes.
KiLer
Re: cooling
did you remove all the other passages the water passes through ? Hoses,thermostat housing etc. check them for blockage as well.....does the temp. rise straight up or does it take awhile ? how much oil are we talking here ?
luisito
Re: cooling
i don,t know is the head is warped until monday went i take to be tested. <br />this eng. was on unheated garage for 2 years <br />this is the first time it run since
luisito
Re: cooling
yes i check all the passages i find a lot blockage but all the oil is mix with water
