salted nuts
- Jul 6, 2003
- 12
I have been getting a high temp alarm after cruising for a while. I just replaced a broken reed valve #2 cyl. I opened the head cover - no obvious problem, same with exhaust cover/gaskets.I also pulled the thermostat and poppet valve - all in good working order. I get very little pressure and air/gas in pee hole stream. There is a lot of warm water running out of the front of the foot. I replaced the water pump impeller and pump/tube seal. After pressurizing with a garden hose, foot off, I can see water running out from the drive shaft hole. Where could this water be comming from and why do I not have any pressure.
