Here is the cooling pathway from the factory manual. What happens at the Y where the input line comes into the midsection? How does the water split off to two sides?
Water goes into the powerhead via the two sides where it is marked blue:
Then up up to where the rectifier sets:
Cooling the exhaust ports from the cylinders (and warming the water):
Then the water makes its way back down to the bottom of the cylinders:
Comes in to the water jacket around the cylinders and works its way up to the thermostat:
Then, comes through the thermostat when the temperature is correct (or through the poppet valves under high pressure):
Then goes out the bottom of the head (marked in red):
Then comes out the bottom of the block on both sides (where it is marked red):
Going down the leg and out the exhaust vents and prop.
Does this look correct?
My Questions are as follows:
1.) How does the water Y off from the input line? Is it just a casting in the exhaust housing?
2.)Is photo 4 correct? Are those the exhaust ports from the cylinders?
3.) Does that cavity (under the rectifier) fill completely up with water? Does the water travel in and up, then back down to enter the bottom of the cylinder water jacket?
Thanks guys. I also hope this helps anyone wondering how the cooling system works on these motors.
