I have a 1992 15HP manual short shaft I am trying to get going.  It has been sitting for about a year.  Last year I replaced the impeller and water pump housing.  When I cranked it a couple of days ago it cranked fine but water wasn't making it out of the lower unit.  It was just flowing out the lower unit.  Sooo.... I backwashed the water reservoir from the motorhead and water flowed fine in reverse.  I checked the pee hole, fine.  I checked the hose, fine.  I took the lower unit off, removed the water pump, impeller, etc.  Everything looked fine.  I put it all back together the way I know to do.  I know the impeller is pointed the right way.  It still isn't working.<br /><br />Something I noticed in the manual.  In the water pump, there is a quarter circle hole.  The same hole is in the cup the impeller fits in.  Are these two holes supposed to be aligned a certain way.  Mine are pretty much lined up.  The manual looks like they might be opposite one another.<br /><br />One other thing, is it possible the hose that hooks into the water pump isn't lining up??  Is there a trick to lining those things up (since you can't get your hand up in there)?<br /><br />Thanks for any help you guys can offer.
