phoodieman
- Oct 18, 2010
- 42
1967 40 HP RDSL 29E
The manual says, "At low speeds the impeller works as a displacement pump. At higher speeds water resistance keeps the blades from flexing and the pump acts as a circulator, enough water being provided by the forward motion of the motor through the water".
So if I'm reading this right, at low rpm I should have cooling water discharge from the back of the motor, but at higher rpms (and speeds), there shouldn't be any water coming out of the back of the motor. Because at speed I'm not seeing any water coming out of the discharge.
Is this how the motor should operate?
Phoodieman
Phoodieman
