cooling question
snowman52288
i have searched and could not find the asnwer that i was looking for... my question is am i able to take a 351 windsor out of a truck and put it in my 76 silverline nantucket 22 vht, and use a radiator to cool it? i think i have most of the parts to make it a marine motor, but i just thought i would ask and see if it had been done before or if other boats are radiator cooled.
thanks!
-Danny
Bt Doctur
Re: cooling question
The "radiator cooling" is done with a heat exchanger using water as the medium not air.
jtybt
It's been done but on out on the bayou...or so I've been told.
The problem is the radiator needs a constant supply of COOL air.
Mull that over for a while.
snowman52288
could i use electric fans with a hole on the stern to bring in cool air/ take out hot air, and yes they would be mounted up high. or maybe a scoop of some sort off the side or top of the boat to "catch" the air. just a thought, i had these ideas running thru my head and they wont leave me alone!
-Danny
jtybt
You from Looisiana? I heard they do that up Arkansas way, too.
cr2k
The manifolds and rubber connector tubes are cooled by by-pass water, so you would have to supply that to the manifolds. or you would fry your exhaust system.
Kentucky?
Ayuh,... It Won't work.... Dumb Idea,.... The boat is surrounded by cool Water,.. Use it....
mkast
If you take the time to look at a Mercruiser maintenance manual, you'll see how the cooling system operates. Why do you want to reengineer a system that already works?
If these ideas won't leave you alone, what's going to happen when you install a truck engine in the hull?
Some posters are asking where you are from, please change the location in your profile.
marlboro180
Some posters are asking where you are from, please change the location in your profile.[/QUOTE]
Yeah, gonna give us cheeseheads a bad rap:rolleyes:
snowman52288
im still using a motor from a truck ill just need to find a marine intake, make a bracket to move the alt, and yes get a mercruiser book, it was just an idea!
