Re: cooling problems
well got it running today and it didnt get hot like it did before, I realize now that what I thought was the tell tale is actually a drain hole for water under the water level, there is no pee hole above on the port side at all just two exhaust ports on the back under the caseing. well shouldnt have to worry about that if it doesnt get hot. I'll be keeping a eye on it. right now the carbs don't seem to work properly, I got the kits and replaced all the floats and seals, will run fine after but then an hour later it wont start, so take off the carbs drop the bowls pull floats and sprayed out all holes, ran great then again same thing, how are the floats supposed to adjust, there is no adjusting screws of any kind, frustrating after all this work, any thought?
