cooling problems.
joescerros
Please help!!!! just got 95' kawasaki 750 ski, starts runs real good but, not much water out off peehole. Yes, it's running hot, is it a big problem?
bently
Re: cooling problems.
you should check the tube from the jet pump to engine and make sure it is free of sand build-up. Most jet skis that run hot have sand in the cooling system and slows the flow of water, unfortunately you will need to disassemble the motor to completely fix, can not flush it out.
