cooling problem
panhandleiceman
i have a 1991 60hp vro (bypassed) staight 3 last outing hothorn went off after about 20 minutes.After hooking it up to the ears the engine feels hot after about 20 seconds of running. i don't know exactly were to touch engine, but i have been touching it on the space between spark plugs. today i put new t stat in it in a attempt to cool it down, didn"t seem to work. new t stat(black) didn't look like old one (white). a good stream is coming out of the pee hole however it is not warm at all (normal??). How long does it take for t stat to open at idle. thanks for any suggestions
OBJ
Re: cooling problem
Iceman....where ya' need to check is the flat place on top and just forward of the head. If you can leave your fingers on there, with the engine warmed up, for several seconds, the engine temp should be OK.<br /><br />The pee stream shouldn't get warm. This is direct from the water pump where it enters the exhaust cover. <br /><br />Is all connectors associated with the VRO disconnected? There should be what looks like a black light cord from the VRO oil tank that should be disconnected and a Amphenol connector from the VRO pump that should be disconnected. If so....read on.<br /><br />If the overheat horn is still sounding, look on the head for the temp sensor wire...a tan with a blue stripe wire. There will be a rubber tube covering the knife connector. Pull back the tube and disconnect the knife connector. Turn the key on.<br /><br />If the horn still sounds with the knife connector disconnected, the horn module is probably at fault. They do go bad. Or, you have a short somewhere in the wire going to the horn. I would bet on the module being bad.<br /><br />If the horn stops sounding with the knife connector disconnected, the temp sensor is probably bad. Replace it.<br /><br />Keep us posted as to what ya' find. If you have anymore questions, don't hesitate to ask. Thanks.
panhandleiceman
Re: cooling problem
Another question is that on the thermostat there ia a tiny v shaped groove in one of the square openings on the t-stat assembly. Does it matter if it faces up, down, left, or right.<br /><br />p.s. i plan to go run it this weekend and see what happens<br />o yea, vro is disconnected properly and hot horn is new but temp switch wire is tan with no stripe ( problem??) thanks for the help
