cooling problem
treeguy1313
i have an 82 cutter...with a inline 6 mercruiser 165 hp...and an r out drive...not positive...just bought boat....i am having cooling probs....doesnt seem to be pumping so much...had bees in the water tube...cleaned it out...checked impellar...and still not pumping...heats up....real fast....any ideas????...thanx for any replys...maybe i should just replace the whole pump?
Re: cooling problem
That might be a good place to Start.........<br /><br />While you have everything apart, Flush out All the passages.....<br />Disconnect the Incoming waterline from the T-stat housing,+ Flush back to the Impeller pump........<br />That'll help guarantee that the motors Getting it's water........<br /><br />If that doesn't cure it,<br />It's on to the T-stat, waterpump, manifolds, or riser................
Don S
Re: cooling problem
Also check the exhaust riser. if the passages are plugged up, even the best pump can't pump enough water through it to cool.
b20
Re: cooling problem
and the water pocket cover in the leg.if it's had an overheat that'll be distorted and be allowing exhaust gas into the cooling water.
waterone1@aol.com
Re: cooling problem
In addition to the above (great advice),raise the drive and take a look at the water hose where it connects to the gimbal housing (make sure it's not cracked and leaking). Also remember that a good impeller is a very tight fit inside of the housing. I usually have to coat the housing or impeller blades with dish washing liquid just to lubricate it enough to get it to slide into the housing. If this doesn't sound like your impeller....replace it.
treeguy1313
Re: cooling problem
well ty for all the advice...it will help me alot in my job ahead...again thanx
