Pump doesn't prime. I've put in barrel started motor but no water flow. With motor running I then removed thermostat cover and stat, then used water hose to put water in stat housing area, after short while water starts to flow normally thru motor. At that point without hose, water pumps good also good stream out tell tale. However if I stop motor and restart in a few minutes, no water flow. Also, after using hose to prime with motor operating I reinstalled stat and cover, water continued to pump good. Why won't it self prime ? Any help would be appreciated. Thanks.
