the motor does not seem to run too hot (157 degrees with a digital thermometer ) and the pee water is strong...but no water comes out the two holes on the leg of the motor..I also have a 1978 175hp that has a good stream coming out of these two holes ...not hot but runs at a max of 130 degrees...I am wondering if I need to replace both thermostats on the 150 to get water out of the leg?????
thank you
Robert
thank you
Robert
