Re: converting Volvo Penta dual prop to single
I'm asking is because there is a boat that I'm trying to buy with a 4.3 GM and a Volvo Penta DP outdrive but it is missing the lower unit
With that information there is no way to answer your question, except to say a single prop lower unit can be installed in place of a DP.
But without knowing what year, model drive you have. It's impossible to say which ones will fit. You also have to find one with the correct gear ratio.
Then, what shape is the upper gear box in, why is the lower missing.
You could be wanting to buying a whole load of problems you can't afford.
If you don't know anything about boats or mechanical things, find something to buy that actually runs. It will be cheaper in the long run.
