converting type 1 to type2
j rod
i have a '79 175hp type 1 motor. the cylinders and pistons are shot so im gonna try to use a type 2 block and pistons to rebuild the motor. has anybody done this and/or does anybody have any suggestions. it would be very appreciated.
DHPMARINE
Re: converting type 1 to type2
j rod ,I got lost over type 1 and type 2.Can you explain a bit more?<br /><br />DHP
WillyBWright
Welcome to iboats.<br /><br />Do you mean 2.4L vs 2.5L?
j rod
im pretty sure it is the 2.5. the motor that i took a part was a '79 model. in the early 80's they modified that same powerhead. so the first one is a type 1 and the second is a type 2. i was going to try to take the componets off of the older model and put them on the newer one. i was wondering if anybody had done this or had any suggestions. i did not know if it would work. they look exactly the same except for a poppit valve under #5 clynder. thanks a lot.
