Converting to power tilt/trim-1985 115hp
lwnmwrmn
I have a 1985 Evinrude 115
I want to convert to power tilt
Is it as simple as getting the power unit on Ebay ($300), bolt it up and wire up the switch or does the mounting bracket need to be replaced also?
ezeke
Re: Converting to power tilt/trim-1985 115hp
You will need the relay control box, wiring harness, trim switch and trim gauge plus the hardware. The whole kit new including instructions is part # 0173827.
The wiring harness and control box is #0582192.
I believe that you will also need to remove the shock absorber.
