Converting analog video to digital....HOW?
waterinthefuel
I have a rather nice Sony Hi-8 camcorder. If I could convert my videos from it to a digital format, I could send videos to friends and family. Anybody know if this can be done simply, and for free? My video card is a Nvidia 7900GS with an S-video plug. My camcorder has an S-video out plug, as well as the standard RCA type connections. I don't know if the one on the video card is an input or output though.
Any help would be greatly appreciated!
Xcusme
Re: Converting analog video to digital....HOW?
I'm pretty sure that the s-video is an output. You'll need a video capture card (some are external) to do the conversion. I've converted cam tapes to digital format with an older Hauppauge TV card and burned them to cd/dvd.
ezmobee
What Xcuseme said. Most newer TV Tuner cards also have a line in. Usually S-video. This will work for what you're trying to do.
ThumbPkr
I use a capture card and windows movie maker for my videos.I hear that there are some Super8 cams that can convert the Hi8 tapes and spit them out as digital files but I don't have anything that new that works so I am not sure.I have read about it but not all cams can do it I am told.
The capture card method is slow but Windows Movie Maker allows you to edit your vids and the end result produces a smaller file so the time is well spent IMHO.Ron G
rogerwa
The analog capture cards are encoders (taking analog signal and converting it to digital stream). The good cards use h/w based encoding which will offload the encoding load off your processor. With the included S/w you should be able to specify the final encoded format and quality which corresponds to the final size. If you need to re-encode or transcode, you will be waiting on your processor to do that.
While there are a ton of them out there, the happauge 150 is a good all around card that have the necessary inputs. There are other solutions that allow just composite in. The 150 can be had for $50-60.
Gary H NC
The Nvidia cards are S-video out. The TV tuner cards with a video input would work.
Sorrento 25
Your best bet is probably the Canopus AVDC55 or AVDC110. One benefit is that the AVDC does the processing and not your PC. About 2 bills though...
waterinthefuel
For that much I could just get a new digital camcorder.
Sorrento 25
Spose so... I guess it depends how much existing analog video you have that you would like to convert?
ThumbPkr
That card will do the job.You can buy them on ebay as well for cheap,there are always several listed there.Ron G
