Converting 4HP Johnson from short to long shaft
John Lancaster
I have a 1984 4HP Johnson Sea Horse s/shaft(BJ4BRCRM) which works well, I have heard these can be converted to l/shaft. Is this correct,is it easy to convert, where would I get one and how much would it cost. Thanks.
KenOhki
Re: Converting 4HP Johnson from short to long shaft
shop quoted me 200 bucks to go from long to short on my 15 johnson. to bad yours is a 4 or I would trade you for parts. I would imagin its close to the same price either way.<br /><br />to make your motor a long shaft, you need<br /><br />longer drive shaft<br />longer water pipe comming off the pump<br />longer gear shift linkage.<br />and the 6 inch spacer that will make your motor a long shaft.<br /><br />I think that is pretty much it. I would ask around for someone to trade parts with. or flat out trade motors with to get what you want.
larry agster
i have a 1984 4hp johnson sea horse s/shaft(bj4brcrm) which works well, i have heard these can be converted to l/shaft. Is this correct,is it easy to convert, where would i get one and how much would it cost. Thanks.
hello, i am considering converting to a short i have a long shaft on mine with a extra sleeve and i would consider a trade,
what type of a boat do you have that you feel you need a long shaft. I have a 14 ft v hull aluminum so i thought a short would be better, but i just bought the motor today and not been out yet with it.
I think mine is belgium made i think that is what the b after the 4 means but correct me if i am wrong
my model# is j4brhcrm
why is there a b in front of your model number
and why don`t you have a h before your c
i was told that mine was an addon kit.
larry825@yahoo.com
larry8251@cox.net
