Converting 25" shaft to 20"
Dwhite2
I have a 2014 mercury 115 fourstroke that I am converting and my question is does anyone know how to take the 5" section out on the lower shaft
Dwhite2
Where to buy lower unit
Need help locating a lower unit for a 2014 mercury 115 fourstroke. Serial number 2B053253 . Any suggestions??
GA_Boater
You need a long shaft lower unit. And shift shaft, water tube and mid-section.
Dwhite2
Changing it to a short shaft so I need a 20" lower unit for 2014 mercury 115hp fourstoke sn# 2B053253
Short shaft is 15", long shaft is 20", XL shaft is 25"
You need a long shaft lower like GA stated
Dwhite2
Ok , thanks for that info . Now I just need to digi out how to take the 5" spacer out , it won't budge
GA_Boater
Do you have a 5" extension kit installed and you are trying to remove it? This is far different than converting a factory extra long motor.
GA_Boater
Lets see a pic of the stuck driveshaft extension. Your diagram isn't showing what you are having trouble with.
The extension slides in the end of the driveshaft, matching the spline. Put the lower unit in a vice with some wood clamping the driveshaft, heat it and use a crescent wrench adjusted so is just loose on the driveshaft and tap the extension off, using a hammer if needed. Soaking the joint with your favorite rust loosener solvent may help.
Dwhite2
The lower unit with the drive shaft is off but the 5" spacer is still attached to the gear housing . Is it just held on with a couple of dowl pins ??
