Bass-by-you
- Sep 14, 2009
- 62
I have a 1984 model cuddy cabin. Just acquired this summer. I have been refurbishing during the last few months. On the cabin wall is an elec. panel. There are 2 rows of of swithes. Top swith on one side is main for 120 volt shore power. Top switch on the other row is 12 volt main. On the 120 volt side is a switch labeled "converter". I have removed the panel from the wall to take a look. Questions:
1. Is a converter not a "boxy" item located at a position other than the immediate wiring of the panel?. Should I be looking for an elec. device somewhere else that this switch goes to?
2. Isn't a converter the opposite of an inverter? That is to say, if the shore power is plugged in, shouldn't I get pwer to the 12 volt side. I only seem to get power to the 12 volt side if I have the main battery switch turned to one of the main batteries.
3. If the converter is working and I have plugged into shore power, should I not be able to run my 12 volt systems as well as charge one or both of my batteries?
4. How do I test a converter to determine if A: it is getting power to it, and B: if it is putting out 12 volt power (if that is what it is supposed to do?)?
I apologize for the ignorance....this is just not my area of expertise.
Thanks guys
Thanks guys
