As I start on my trailer to get it refurbed, I'm beginning to wonder about it. I'll attach a picture and explain my concerns.<br /><br />
<br /><br />This trailer has 16 rollers arranged in groups of 4. All 16 need replacement. I am concerned that they do not provide enough support to the hull. The boat weighs 2400lbs empty + 36 gal fuel and maybe 200lbs misc gear. The trailer is rated to carry 3200lbs, so I am within its range. The hull by itself is 1400lbs witha 1000lb engine/outdrive combo (V8+#1R). The rollers do not support the last 6" of the hull. <br /><br />To me, 16 rollers is not enough for this weight. Converting to straight bunk would be difficult due to the lack of a crossbrace in the middle of the trailer. What I am considering is to replace the front 8 4" wobbles with new 3x5" ribbed tire type rollers and replace the back 8 with 4 lengths of 2x6 bunks to support the back of the boat. I would be attaching the 2x6's to the existing roller platform with some u-bolts and blocking or by making a T shaped bunk and hanging it by the roller shafts with some bracing or blocking so it could still adjust as the boat settles.<br /><br />Does this sound feasable or worth the effort? Am I wrong about there not being enough support? If my idea doesn't work, I could always go back to the original setup as I wouldn't be modifying the original supports, gust building on them. Anyone try this before?
