hullofalottatrouble
- Jul 16, 2005
- 306
i have a 1982 merc 260 with mechanical fuel pump which has a sight glass attached directly to the pump.. the connection to the pump broke.. is there an easy way to convert it to tube instead of the glass? can i attached a nipple and clear tube and run that to the carb? i havent looked up the info on this yet.. just thought i would send this out and bounce it around a bit..
wonderin if i can add a tube to my current fuel pump? there is the threaded connection from the pump to the glass.. can i attach a nipple and tube to that fitting and run that to the carb?
thanks
thanks
