Control Shift Compatibility Question
PWH1
Hello,
I am replacing my old side mount control (volvo penta part #174931) and before I purchase a replacement wanted to be confident it the compatibility of my selection. I am eyeing the Uflex B184 Single Lever Side Mount Control with Trim as the replacement. The control would be mated to a 1997 Johnson 90 SPL. I will as well be running new shift cables (are Teleflex cables - compatible?) when installing the new control. My boat has a ignition in the dash and I was also curious if the
Uflex control requires any special wiring adapters or if I will be able to tie directly into the trim and ignition wires that were separated from the old controller?
Thanks for any feedback.
