Bryant Davis
- Jan 8, 2002
- 24
I just bought a 1977 70hp Evinrude to replace a blown 1986 40hp Evinrude I had on my boat. I have noticed that the motor end of the control cables have different connections. I was wondering if the control box ends are the same. In other words will I still be able to use my "1986" control box with the '77 motor. I know that the wiring harness is the same.<br /><br />Also, this motor has been sitting for a while and I tested compression before buying it. Compression showed high on the motor cold (135, 130, 128) but after running the motor a few minutes the compression read 125, 125, 123. I was impressed for a motor this age but should the cold readings be of concern or is this normal? All reading were with all plugs removed.<br /><br />One last question...I plan to replace the water pump prior to installing this motor. Should I replace just the impeller, the whole kit or what?
