chrismarion
- Apr 12, 2006
- 115
I have been redoing my boat since I purchased it in March, which was a halfway completed project by the previous owner. Anyway, I got my 12 block fuse panel (Blue Sea 12 position #5026) with combined ground block all wired up and mounted. I have two batteries under the center console also with two Perko selector switch's for the engine and fuse panel.
Now what I have done so far with the fuse panel (which has running lights, 12v plug, fishfinder, bilge pump, aeriator and radio wired in and fused so far) was use the Blue Sea water proof switch panel with breaker & LED. The top switch I wired it to have a constant 12v (fused) and be able to switch it on which then kicks the solenoid to give power to the fuse panel for my accessories which are also run off of the switch's. But they cannot turn on with the switch's unless the "12v Power" switch is on.
Problem I am having is the solenoid aparently is overheating. Its not burning hot, but its warm. After about 30 minutes it kicks off. Does anyone have a suggestion on what is THE BEST water proof, heavy duty, continous duty cycle solenoid to use? Or maybe another way to do what I am going for. I really like how everything is set up nice and neat without the possibility of forgetting to "disconnect" power to the panel or accessories. Cant miss the LED for the "12V Power" switch.
Thanks guys, Chris
Thanks guys, Chris
