nautihabits
- Aug 28, 2005
- 42
I have an 1998 A2360 A=alluminum, 23 = ft., 60 = 6,000 lb. GVWR is 6,700 lbs. The rear cross-member is a 3.5 or 4 " square alluminum tube. This cross-member bolts to the underside of the trailer I-beams and supports the trailer bunks at the back of the trailer. The I-beams are bolted to the cross-member as follows: The inside lower flange of the I-beam is connected by a U-bolt that runs underneith the cross-member (a solid connection) the outside lower flange of the I-beam is bolted through the top plate of the (square tube) cross-member. The top of the cross-member is now peeling back adn the I-beam leaning in towards the center of the trailer. Anyone experienced this happening? Boat is a SeaRay Laguna 23 (1989) w/ 250 Yamaha, 115 gal. fuel, 20 gal. water. Shouldn't be to heavy for this trailer should it?
