Hello,
I spent the weekend reading a lot of the oil/tempature alarms here, good information. I read my Seloc manual, but I am still having problems identifying what is the temp sensor, and what do disconnect to isloate the alarm problem.
Problem: Constant solid alarm when key is turned, with cold engine. When engine is started, still cold, constant solid alarm.
Tested:
Oil tank on engine is full with oil
Disconnected the blue wire comming from oil tank cap, alarm still present
Disconnected:
Green wire going to Lubalert (alarm still present)
Purple wire going to Lubalert (alarm still present)
There are 2 wires connected directly to the engine, hard wired, by the spark plugs, I belive these are temp sensors?
Tan wire and black ground on one side
Black, (I think) on other side
Are these, hard wired wires to the engine, the tempature sensor wires that I should disconnect to test to see if the alarm stops? If the alarm does stop, would that point to a temp sensor problem, since it alarms when engine is cold.
Where are the temp sensors located so I can replace them.
Thank you.
Tested:
Disconnected:
Thank you.
