Considering buying 1990 Bass Tracker With 40HP Johnson 2 Stroke-Want Opinions
Jim Cahoe
I am considering buying a 1990 Bass Tracker V17T with a 40hp Johnson 2 Stroke. I have been told it doesn't come out of slow mode but runs fine. Don't know what I am getting into.
Also is a Johnson 40hp 2 stroke a good engine? Is 2 stroke common on boat motors. This will be my first boat. I no next to nothing about boats. I just wanting something nice to fish from.
boobie
Re: Considering buying 1990 Bass Tracker With 40HP Johnson 2 Stroke-Want Opinions
JMHO. Stay away from it and look for something else. There's plenty out there.
JB
That boat is underpowered by a sick engine. Take boobie's advice.
Silvertip
Saying that without ANY justification is of absolutely no help.
Silvertip
Two strokes have been the design of choice for eons and 4-strokes have come onto the scene only recently (as in the last 12 years or so. Depending on price, you might have a very worthy fishing boat but it will not be speed demon. Those are good motors but like anything else, value depends on what you have to pay for it. Slow mode is triggered by the temperature sensing circuitry. It may have a bad temp sensor or it may have a bad ignition module. Mention Tracker and many folks (me included) will tell you that they tend to power their package boats with the least amount of power possible just to keep the cost down. Therefore folks tend to trade/sell them for a better performing rig. How you intend to use the boat and how much power you need is strictly up to you. Since you know nothing about boats you can use this one as a way to learn -- but it must be purchased inexpensively. No sense paying full price for a boat with problems when you can pay full price for one that has none.
boobie
Learning on a boat that has problems can get expensive. Especially when you have no experience with mtr or boat repair.
Home Cookin'
from your questions and your admission, you are not the right candidate to start with a broken down motor. A starting-out boater doesn't need new or fancy, but he does need reliability, ande you have to pay for it.
Yes, the 2 stroke outboard is the work horse of the boating world and the place to start--but start with one that is running well, and running well according to someone who knows and who can be trusted.
For a relatively small basic fishing boat, focus on the outboard, first. Then you need a hull that is safe, so stick with boats that are made to handle age and weather--aluminum, or solid-hull* fiberglas, or "no wood" or self-bailing decks, especially around fresh water where there is risk of rot in the hull with boats that hold water in the bilge (under the floor).
A free boat never is, and a cheap boat usually costs more, especially for the inexperienced.
Welcome to boating and iboats! be safe and pay attention. when the time comes, take a boating safety course.
*a boat with no air space between the floor ("deck") and the outer hull, such as a Boston Whaler--actually there are two hulls, inner and outer, filled solid with foam in between ("core"), so practically speaking to a layman, it's a "solid hull."
joelybob
not everyone can afford a fancy perfect boat. If you can buy it right. I take a little pride in finding a boat that needs a little tinkering and make a project out of it. and the plus side you get some experience on working on them. I say if you like the boat buy it.
Texasmark
I like the idea of low power for your first boat. It will give you time to learn a few things about boating before you become dangerous to yourself and others.....read my caption.
Best thing you can do is enroll in a safe boating course. You can never know too much about being out on the water and the water is not forgiving................and you usually can't stop on a dime (trick manuevers excepted) like you can in a car.
Mark
bonz_d
Another option if you really like the boat would be to call a local repair shop, explain your situation, explain what the seller has told you and get a ballpark estimate for the repair then go back and make an offer for less the repair cost.
The Trackers are not that bad of a boat and those Johnsons and Evinrudes are great motors when they are running correctly and kept up with. Yes that boat is underpowered but not unusable. That boat would be much better served with at least a 70hp on it.
roscoe
I say keep looking.
Don't buy a boat with known problems if you aren't sure of the cause, and how to fix it.
If it was something easy or cheap, the seller would have fixed it.
When you find a decent running boat, ask for a water demonstration.
If you don't have a friend that can show you the ropes, try offering the seller $50 to take you out on the water and show you the basics.
