connecting rod bearing 1979 55 hp evinrude
asthedeer
Hi everybody Iam doing an engine rebuild on this engine
Just wondering if you can use a cage baring on a floating wrist pin for the connecting rod?
The model # is a 55974c
Thanks a bunch
Colin
Daviet
Re: connecting rod bearing 1979 55 hp evinrude
By the parts breakdown it looks like it is a caged bearing on the wrist pin.
Faztbullet
Yes as long as its a 3/4 dia wrist pin, the aftermarket part # is wp13c...
Chinewalker
I believe they recommend the newer style with the loose needles and the guide washers at the ends. I've seen some of those older style ones come apart and destroy a motor...
